| Product(s): | ProjectWise Dynamic Composition Server (DCS) | ||
| Version(s): | 08.11.11.xx | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Dawn Gentry, Bentley Technical Support Group | ||
When running interactive jobs or automatic scheduled jobs in DCS, the following errors may occur:
Failed to create plot set on PPD-HQ-A68: System.UnauthorizedAccessException: Retrieving the COM class factory for component with CLSID {CAC2C26A-4215-11D0-98FB-08003601E054} failed due to the following error: 80070005.
or
The following error occurred on BIMEMEASS4 inside InterPlotProcessor.TopLevelExceptionHandler:
Orchestration Framework based ProjectWise products do NOT support non-admin shepherd users. The account set on the Log On tab of the ProjectWise Orchestration Framework Service must be a member of the Administrators group.
