| | Applies To | | |
| | Product(s): | InRoads | |
| | Version(s): | 08.11.07.615 | |
| | Environment: | N/A | |
| | Area: | Geometry | |
| | Subarea: | | |
| | Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | |
Question:
How do I to export files of type *.ASC and *.SOE?
Answer:
- Go to Tools > Application Add Ins
- Toggle on "Cross Section ASCII Report Add-In". This command creates a station, offset and elevation report for a specified cross section set.
- The command will now be located at Evaluation > Cross Section > Cross Section ASCII Report. One of the options will be to create an ASCII file of the report.
