Applies To | |||
Product(s): | Bentley MXROAD | ||
Version(s): | 08.11.09.493 SS3 | ||
Environment: | N/A | ||
Area: | Settings | ||
Subarea: | Project Explorer Setting | ||
Original Author: | Amita Shinde, Bentley Technical Support Group | ||
In order to disable or enable any of the options in the "Project Explorer" panel, the setting is found under "Settings > Project Explorer" in the CAD menu. Setting the value to "True" shall enable the option in the panel.
