| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.07.420 | ||
| Area: | IPLOT | ||
| Subarea: | |||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
A default Iplot settings file (filename.set) is being applied each time user opens the Iplot dialog from within MicroStation. No Iplot.set nor printer-name.set file exists. (These typically run automatically when the Iplot menu is activated and/or when a specific printer is selected). Why is this behavior occurring?
User had previously defined the IP_DEFAULT_SETTINGS variable in their MicroStation User workspace. Once this variable was removed, the settings file no longer applied itself automatically.
