| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.07.XX | ||
| Area: | Organizer | ||
| Subarea: | |||
| Original Author: | Dawn Clark, Bentley Technical Support Group | ||
I am defining IPLOT_MSENGINE_OPTIONS, but ProjectWise InterPlot Organizer appears to not accept the value.
There is a syntax error in the value of IPLOT_MSENGINE_OPTIONS.
If the path name to the argument contains a space, you must use the correct syntax to preserve the quotes.
For example:
IPLOT_MSENGINE_OPTIONS = "-wc~"C:\Program Files\Bentley\MicroStation V8i (SELECTseries)\MicroStation\config\mslocal.cfg~""
Notice the quotes around the entire argument and the tilda used as an escape character to preserve the inner quotes which preserve the spaces in the path.
