| Product(s): | InRoads | ||
| Area: | Surface | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
How can the area between two contours be determined?
Create a surface with outer contour having a point type as exterior and the inner contour having a point type as interior. Then use the Evaluation>Surface Area command to attain True Area and Planer Area.
