| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.07.420 | ||
| Area: | |||
| Subarea: | |||
| Original Author: | Larry Abla, Bentley Technical Support Group | ||
Make sure your entire drawing is captured in InterPlot Organizer PDF files.
By default, PDF files produced using InterPlot Organizer - Export PDF are created with the view parameters last saved for View 1.
Make sure your drawings "fit" in the output PDF file that is generated using the entire drawing regardless how it was last saved in MicroStation.
This works for both .dgn and .dwg files.
