| Product(s): | InRoads | ||
| Area: | Cross Sections | ||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Are edits made with the Change Triangle Edge command permanent?
All changes made using this command are saved to the DTM, however, If the surface is retriangulated, any changes made with this command will be lost.
