| | Applies To | | |
| | Product(s): | InRoads | |
| | Version(s): | 08.11.07.615 | |
| | Area: | Cross Sections | |
| | Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | |
Question:
How can I offset a drainage network a specified amount from it's current location?
Answer:
- Create a dummy horizontal alignment that extends the length of the network.
- Use the command Geometry > Utilities > Parallel Horizontal Alignment to create a second alignment that is offset the same amount that you wish to offset the network.
- Use the command Drainage > Network > Move to offset the alignment using the option to "Move Relative to a New Alignment".
