| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.07.420 | ||
| Area: | IPLOT | ||
| Subarea: | |||
| Original Author: | Van Kendall, Bentley Technical Support Group | ||
I am getting the following error when I Export to PDF from the IPLOT Main dialog or InterPlot Organizer:
Could not establish message connectivity with the Document Set Renderer (HRESULT=0x80004002)
Open the registry on the machine:
Go to the following location: HKEY_CURRENT_USER\Software\Intergraph\InterPlot Professional\CurrentVersion\ProjectWise InterPlot Organizer V8i (SELECTseries 2)\Options
Create a new string value under this key called DsrClsContext.
Set its value to inproc_server
