| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.11.34 | ||
| Area: | IPLOT | ||
| Subarea: | |||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
How can I display the level names instead of level numbers in a IPARM file?
Set the variable IPLOT_SHOW_LEVEL_NAMES = TRUE in the iplot.cfg file
How to do that:
Start -> All Programs\Bentley -> ProjectWise InterPlot Utilities -> ProjectWise InterPlot Organizer Configure -> Configure …-> MicroStation -> Edit… -> Client – iplot.cfg TAB -> Text Editor ->
set the variable:
-> File -> Save-> File -> Exist -> ok -> Close -> Exit Configure
