| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.11.34 | ||
| Area: | Organizer | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
How can InterPlot Organizer be configured to output an “Export PDF” to a specific folder?
Use IP_ORG_PDFOUTPUTDIR in ip.cfg to define the desired output folder.
