| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.07.420 | ||
| Area: | IPLOT | ||
| Subarea: | |||
| Original Author: | Larry Abla, Bentley Technical Support Group | ||
Vector lines and text plot darker than the same RGB values for filled shapes on a Oce TDS 700
Change “Vector Rendering Mode: to Full color all” (Full Color Above Pixel Threshold is the default setting) in the Graphical Attribute Editor for the printer on the server AND in Rendering Attributes for Print Setup… in your .ips file (let all of the sheet definitions update) and everything should plot the same
