| Product(s): | ProjectWise InterPlot Server | ||
| Version(s): | 08.11.07.420 | ||
| Environment: | Window Server 2008 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Larry Abla, Bentley Technical Support Group | ||
When sharing a Local Printer from a ProjectWise InterPlot Server 2008 R2
machine, you get the error "Printer Settings could not be saved. Operation could not be
completed (error 0x000006d9)".
One cause of the error 0x000006d9 can be that the Windows Firewall was turned off.
Turn the Windows Firewall back on - Share the printer - turn the Windows
Firewall back off (but only if necessary).
Keep the Windows Firewall turned on
