| Product(s): | ProjectWise InterPlot Professional | ||
| Version(s): | 08.11.07.126 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Organizer | ||
| Subarea: | |||
| Original Author: | Ed Yepes, Bentley Technical Support Group | ||
When user invokes Organizer from the IPLOT dialog box or from a shortcut all he gets is the GUI with "Welcome to ProjectWise InterPlot Organizer". If you cancel or select any of the choices, the GUI disappers and you see InterPlot Organizer in the task bar, but nothing happens when you click on it.
Now invoke Organizer
