| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.11.34 | ||
| Area: | IPLOT | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
ProjectWise InterPlot Organizer IPLOT caching.
To configure caching for IPLOT jobs, two configuration variables are provided in the IPLOT.CFG file. The first configuration variable IPLOT_CACHING, determines if the caching feature is on or off. If the caching feature is off, the Caching tab is removed from Organizer's properties dialog and caching is off for all IPLOT jobs. The second configuration variable IPLOT_ENABLE_CACHING_DEFAULT, determines if caching is enabled for individual IPLOT jobs. If this variable's value is set to True and IPLOT caching is on, caching is automatically enabled when a job is added to Organizer. This configuration variable does not affect files that have already been added to a plot set.
