| Product(s): | ProjectWise InterPlot Organizer and Professional, ProjectWise InterPlot Server, ProjectWise InterPlot Driver Pack, ProjectWise InterPlot Mid-Volume Driver Pack, ProjectWise InterPlot High Volume Driver Pack, ProjectWise InterPlot Raster Offline Driver Pack, ProjectWise InterPlot High Volume Driver Pack, ProjectWise InterPlot Raster Offline Driver Pack | ||
| Version(s): | ProjectWise InterPlot Organizer 08.11.11.xx | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
This technote lists the minimum technical requirements for the ProjectWise InterPlot V8i Products.
ProjectWise InterPlot Organizer is required on each machine needing to submit plots to ProjectWise InterPlot Server. ProjectWise InterPlot Professional can submit plots to ProjectWise InterPlot Server or plot in a standalone mode without ProjectWise InterPlot Server.
Processor: Intel® or AMD® processor 3.0 Ghz or greater.
Memory: 512 MB minimum, 2 GB recommended. More memory will almost always improve performance.
Operating Requirements: Windows XP Professional (32- and 64-bit), Windows Vista (32- and 64-bit), Windows 7 (32- and 64-bit), Windows server 2003 (32-bit), Windows Server 2008 (64-bit), Windows Server 2008 R2 (64-bit).
Supported File Formats: MicroStation (all versions), AutoCAD (releases 10 through 2012), raster files (such as TIFF, CALS G4, and JPEG), and ProjectWise InterPlot (DPR) files.
Software Prerequisites: The Prerequisites for Bentley Desktop Applications v08.11.09.03 needs to be installed to your workstation prior to the installation of ProjectWise InterPlot Organizer v08.11.11.xx.
Memory: 1 GB of RAM minimum, 2GB recommended.
Operating System: Windows Server 2003 (32-bit), Windows Server 2008 (64-bit), Windows Server 2008 R2 (64-bit).
Software Prerequisites: The Prerequisites for Bentley Desktop Applications v08.11.09.03 needs to be installed to your workstation prior to the installation of ProjectWise InterPlot Server v08.11.11. Microsoft XML Core Services 4.0 SP2 or higher is required on the ProjectWise InterPlot Server Web Server for the Web Pages to operate correctly. If not already installed, these core services can be installed via the MSXML installer located in the "systools" directory of the ProjectWise InterPlot Server delivery folder.
The following specifications are for using ProjectWise InterPlot's Digital Archiving Feature:
Plot Server: Must have ProjectWise InterPlot Server installed.
File server: To store the digital plots created for ProjectWise InterPlot Server archives, the file server must expose LAN Manager file shares that are accessible with Microsoft's Universal Naming Convention (UNC).
Web server: To view ProjectWise InterPlot Server archive web pages, Microsoft Internet Information Services (IIS) 6.0 or later for Windows Server 2003 and Microsoft Internet Information Server (IIS) 7.0 for Windows 2008, ProjectWise InterPlot DPR Web Utility, Microsoft XML Core Services 4.0 SP3 or later.
Supported Databases: To store ProjectWise InterPlot Server archive attributes, Oracle9i*, Oracle10g (10.2g), Microsoft SQL Server 2000, Microsoft SQL Server 2005, Microsoft SQL Server 2008 and Microsoft Access.
* Requires Oracle8 Client software
Supported Web browsers: Microsoft Internet Explorer version 6.0 or later.
Operating System: Windows Server 2003 32-bit, Widnows Server 2008 64-bit, Windows Server 2008 R2 64-bit.
Content Publishing – ProjectWise InterPlot SELECTsupport Technotes and FAQs
