| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.11.34 | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
I have not been able to adjust the line weights of text placed with Arial font via IPLOT is there a way to do this?
There is not a way to change the weight or thickness of a True Type Font in MicroStation or using InterPlot. A workaround is to use a non-TT font, or use a Design Script to change the font to a MicroStation font at plot time.
The following Design Script example changes all Arial fonts to Engineering fonts and assigns weight 0.
if (font_name == 'Arial') then
font_name = "Engineering"
weight = 0
endif
