Digital InterPlot Design Script Extensions For ProjectWise Components [CS]
This Client Server article is republished in its entirety from 2004 for reference purposes.
Did you know that you can use ProjectWise-related keywords in InterPlot Design Script language?
With Digital InterPlot 2004 Edition, ProjectWise components can be identified with new Design Script (iplot pen table) keywords to resymbolize the plots, and to create content-rich PDF documents.
The available ProjectWise component keywords are:
Example design script for resymbolization:
! If the PW component is a P0409 pump, then change its color to RED.
if (pw_component_business_key .EQ. "P0409") then
color = (255, 0, 0)
endif
Example design script for resymbolization and to create a bookmark:
! This design script resymbolizes (highlights) those items
! that require maintenance in a facilities drawing and creates a
! bookmark that points to that item.
! Check to see if the element is a ProjectWise component
if ( pw_component_class_name .ne. "") then
! Set the Requires_Maintenance property
! and plot the element red.
pw_component_property_name = "Requires_Maintanence"
if (pw_component_property_value_integer eq 1) then
color = "red"
! Define a Bookmark that will navigate
! to the piece of equipment.
action_item = BOOKMARK
action_name = PLOT_NAME + "." + PW_COMPONENT_BUSINESS_KEY
action_type = AREA_OF_INTEREST
action_instance = SINGLE_INSTANCE
endif
endif
You can find more information about these action key words and rendition features in InterPlot Reference Help under the section for Plotting MicroStation data, Using Design Script/Pen Tables, Iplot keywords for Active Renditions and Creating Active Renditions.
Client Server Archive
ProjectWise TechNotes And FAQs
Comments or Corrections?
Original Author: Bentley Technical Support Group
