| Product(s): | ProjectWise InterPlot | ||
| Version(s): | InterPlot Client, InterPlot Professional, InterPlot Server 9.1, 10.X | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Pattern libraries are collections of area fill patterns. Each pattern has a name, size, rotation and graphical definition. The graphical definition is a 1-bit raster image. IPLOT uses only raster pattern libraries; APLOT supports both metafile pattern libraries and raster pattern libraries. Raster pattern libraries are not valid with vector devices.
Separate patterns need to be drawn for each unique plotter resolution. For example, for a 300 dpi plotter, you should make the raster file pattern size 300x300 pixels. For a 600 dpi plotter, you should make the raster file pattern size 600x600 pixels. By default, 4 pattern libraries are delivered for each resolution: pat100.plb, pat300.plb, pat400.plb, and pat600.plb.
You must use a pen table or feature table to plot elements with the patterns stored in pattern libraries. When you assign a pattern to an element, you can also define its foreground and background colors.
The following IPLOT pen table fills all shaped elements on Level 1 with a blue and yellow hatch pattern:
if ((level == 1) && (type == shape)) then area_fill = true pattern = 'hatch' # pattern name fill_color = 'blue' # background color pattern_color = 'yellow' # foreground color endif
The following APLOT pen table fills all closed polylines with a blue and yellow hatch pattern:
if ((entity_type == polyline) && (closed == true)) then area_fill = true pattern = 'ansi31' # pattern name pattern_color = 'yellow' # pattern color color = 'blue' # background color endif
This is the process for creating a raster pattern:
You can draw the graphical representation with a raster editor like Paint Shop ProTM. Create a 1-bit raster image (TIFF is the recommended format). Be sure to create graphical representations for each unique plotter resolution.
To create a new pattern library, choose the name for the library. The extension .PLB is used to indicate that the file is a pattern library. Use the IPLOT pattern library editor (plib) or the APLOT pattern library editor (applib) as follows:
plib cre iplotpat400.plb applib cre aplotpat400.plb
plib add -entry=mypat1 -file=mypattern.tif iplotpat400.plb applib add -entry=mypat1 -file=mypattern.tif aplotpat400.plbThis example adds a pattern to the 400 dpi pattern library. The graphical representation should have been created at a resolution of 400 dpi.
plib modify -entry=mypat1 -size=1 -units=in iplotpat400.plb applib modify -entry=mypat1 -size=1 -units=in aplotpat400.plb
Configuration Variables (iplotsrv.cfg) IPLOTSRV_PATTERN_LIB_LIST
This variable contains a list of InterPlot pattern library names IPLOT Server reads to resolve pattern name references in pen and feature tables. Multiple library filenames may be specified within this variable, denoting different pattern libraries for different device resolutions. The format is <filename>,<dpi>;<filename>,<dpi>;... For example, the definition IPLOTSRV_PATTERN_LIB_LIST = LoRes.plb,100;MedRes.plb,300;HiRes.plb,600 causes IPLOT Server to use patterns defined in LoRes.plb when plotting to the 100 dpi preview window, but use the patterns in HiRes.plb when plotting to a 600 dpi laser printer. When selecting a library out of this list, IPLOT Server selects the first entry whose resolution matches the target device. If an exact match is not found, IPLOT Server always picks the highest resolution available that does not exceed the device resolution.
IPLOTSRV_PATTERN_PATH
This variable contains the directories that will be searched for the filenames specified by IPLOTSRV_PATTERN_LIB_LIST. When adding your own custom patterns, it's recommended that you copy the default *.plb files from resrc\system into resrc\custom. You may then add your new bitmap patterns to the resrc\custom\*.plb libraries. IPLOT Server will use the libraries found in resrc\custom without you having to modify this configuration file and your modified libraries will not be overwritten when re-installing the product.
IP_NEGATIVE_PATTERNS
This variable can be used to invert the foreground and background colors for all raster patterns plotted by IPLOT Server. You may need to set this variable to true if you are using custom pattern libraries derived from the default libraries delivered with InterPlot 9.1. This variable is false by default, meaning patterns are not inverted.
Configuration Variables (aplotsrv.cfg) APLOTSRV_PATTERN_LIB_PATH
This variable specifies the directories that are searched for the pattern library specified in the APARM. If no library is specified or the one specified is not found, the library defined in the APLOTSRV_DEFAULT_PATTERN_LIB variable is used instead.
This variable defines the pattern library that will be used if no library is specified in the APARM or the one specified is not found.
APLOTSRV_PATTERN_LIB_LIST
This variable contains a list of InterPlot raster pattern library names APLOTSRV reads to resolve pattern name references in pen tables. If this variable is defined, it takes precedence over both the pattern library name stored in the APARM, and the value of the APLOTSRV_DEFAULT_PATTERN_LIB variable. Uncomment this variable definition if you wish to use the same raster pattern libraries that IPLOTSRV uses.
ProjectWise TechNotes And FAQs
