| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | N/A | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
The last 20 cm of the paper printouts are printed filled in black if plotting an A0 Format with MicroStation J and ProjectWise InterPlot Organizer using different printer driver. Smaller sizes can be printed without problems. This problem does not occurs with newer versions of MicroStation.
The following configuration was used:
Server
Windows 2008 R2 SP1 (x64)
MicroStation J
ProjectWise InterPlot Server 08.11.07.420
InterPlot Driver Pack 03.04.04.62
HP Designjet T790ps 44in
HP DesignJet T790 by Bentley
Client
Windows 7 Prof. und Enterprise (x86) ) and (x64)
ProjectWise InterPlot Organizer 08.11.05.42
MicroStation J 07.01.05.03
MicroStation V8 Xi 08.11.07.446
The ProjectWise InterPlot Organizer 08.11.05.42 is not certified for Windows 7, therefore the Server and Client was upgraded with following Versions:
ProjectWise InterPlot Server 08.11.11.56
ProjectWise InterPlot Organizer 08.11.11.56
