| | Applies To | | |
| | Product(s): | InRoads, MX, GEOPAK | |
| | Version(s): | 08.11.07.615 | |
| | Area: | Cross Sections | |
| | Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | |
Problem:
No results when attempting to annotate segments in cross sections
Solutions:
- When annotating segments, you are actually annotating between crossing features. For this reason, the crossing features that you wish to annotate between must be displayed graphically on the cross section.
- On the General leaf of the Annotate Cross Section command, the location must be set to "Object" or "Frame". The cross section segment annotation does not display with the location set to “Axis”.
- If the features do not show up in the list for Segments or Features, check the style assigned to the feature(s) to verify that "Annotation for Cross Sections" is toggled on.
- The surface containing the features must be displayed in the cross section.
