| Product(s): | ProjectWise InterPlot Organizer | ||
| Version(s): | 08.11.11.56 | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
During the installation of ProjectWise InterPlot Server the following InstallShield Wizard error is displayed:
Error encountered attempting to set Spool directory permissions.
Error: 1722
Confirm the Print Spooler service is started and the Startup Type is set to Automatic prior to the installation.
