| Product(s): | PROJECTWISE INTERPLOT ORGANIZER | ||
| Version(s): | N\A | ||
| Area: | Installation | ||
| Subarea: | N\A | ||
| Original Author: | Evert de Jong, Bentley Technical Support Group | ||
How to remove (uninstall) ProjectWise InterPlot Organizer after an unsuccessful installation of ProjectWise InterPlot Organizer when deinstallation fails
in the first place try Uninstalling the product via. Uninstall ProjectWise InterPlot Organizer In case this does not work do the following.
If service ProjectWise IMF Printer Driver Service exists remove this by:
Start Run - services.msc
Stop service: ProjectWise IMF Printer Driver Service
Disable service: ProjectWise IMF Printer Driver Service
Remove service: ProjectWise IMF Printer Driver Service by.
Method 1:
Start Command Prompt with option Run as administrator?
In start-All Programs Accessories Right Mouse Click on Command Prompt.
Chose option: Run as Administrator?
Type in: sc delete "ProjectWise IMF Printer Driver Service"
Method 2:
Delete registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\ProjectWise IMF Printer Driver Service
Remove directories mentioned below:
"C:\Program Files (x86)\ProjectWise InterPlot Organizer" 64 bits
Windows
Or
"C:\Program Files\ProjectWise InterPlot Organizer" 32 bits windows
"C:\Program Files (x86)\Common Files\InterPlot" 64 bits Windows
Or
"C:\Program Files\Common Files\InterPlot" 32 bits Windows
C:\PlotWork
C:\win32app\ingr\ipshare
Remove the following Registry keys:
For 64 Bit computers
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Bentley\InterPlot Shared
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Bentley\ProjectWise InterPlot
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Intergraph\
For 32 bit computers:
HKEY_LOCAL_MACHINE\SOFTWARE\Bentley\InterPlot Shared
HKEY_LOCAL_MACHINE\SOFTWARE\Bentley\ProjectWise InterPlot
HKEY_LOCAL_MACHINE\SOFTWARE\Intergraph\
Reboot the computer.
