| Product(s): | PROJECTWISE INTERPLOT ORGANIZER | ||
| Version(s): | N\A | ||
| Area: | Print/Plot | ||
| Subarea: | N\A | ||
| Original Author: | Larry Abla, Bentley Technical Support Group | ||
ProjectWise InterPlot Organizer crashes when a .vba script is executed from a MicroStation configuration (.cfg) file.
The problem was fixed by inserting the following code in the .cfg file to bypass the .vba file:
%if !defined (_CONSOLEAPP)
xyz.vba
endif
