| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | Client | ||
| Subarea: | N\A | ||
| Original Author: | Mark Marrero, Bentley Technical Support Group | ||
I have over 500 ips files that I need to update the printer they use. Is there a batch function to do this?
You can do this using the iplotorg.exe command line
iplotorg.exe modify “printer=<new_printer_name> <plotset_filename>
For modifying 500 IPS files they can create a batch file to do this. For example:
set PATH=%PATH%;C:\program files\ProjectWise InterPlot Organizer\bin
cd <directory_containing_IPS_files>
for %%f in (*.ips) do iplotorg.exe modify printer=<new_printer_name> %f
