| Product(s): | InRoads | ||
| Area: | Tools | ||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
This video demonstrates how to use the Generate Water Surface Data command to export a cross section file that can be imported into HEC-RAS.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
Recorded in 1024 x 768 resolution.
