| | Applies To | | |
| | Product(s): | ProjectWise InterPlot Organizer | |
| | Version(s): | System.Data.DataRowView | |
| | Environment: | N\A | |
| | Area: | General | |
| | Subarea: | N\A | |
| | Original Author: | Frank Reimann, Bentley Technical Support Group | |
The following error message appears after sending a plot job via the MicroStation IPLOT Main Dialog box using ProjectWise InterPlot Professional:
CMDERR, executed C:\win32app\ingr\ipshare\clntutil\ipsubmit, which failed
Set the System Variable TMP and TEMP to c:\temp
