| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
How to Create Multiple Plots from a Single MicroStation Design File using Organizer.
Using Organizer to describe plot shapes
-From the Create Plots dialog box, click Add.
-Select the design file you want to plot, then click Open.
-From the Create Plots dialog box, under Manually specified options, select MicroStation DGN files.
-From the Create Plots dialog box, click Options.
-Click the Area tab.
-Click the Describe Plot Shape button.
-From the Describe Plot Shape dialog box, specify the Plot Shape properties, and then select Create one plot for each matching shape.
-Select OK three times to bring the plots into the Organizer window.
-Select File – Print to plot the drawings. Using Organizer to specify sheet definitions
-Under Search models, type IP_SHEETDEF_MODELS. To specify design models, type IP_DESIGN_MODELS. To specify all models, type an *.
Select OK two times to bring the plots into the Organizer window.
Select File - Print to plot the drawings.
