| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
How to use a MicroStation variable in an Interplot design script?
The following example uses the MS_RASTER_DEF_DIR variable:
a) Set the variable in MicroStation (MS_RASTER_DEF_DIR=c:\temp),
b) Place the text ($rasterdirectoryinfo$) in design file
c) Create design script as follows and apply prior to printing
envr_variable = "MS_RASTER_DEF_DIR"
if (characters .eq. "$rasterdirectoryinfo$") then
characters=envr_value
endif
