| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
IP Cannot define plot area using a level number.--Cannot define plot area using a level number.
When Level Manager displays a level name with numeric characters only, quotes are required around the numeric characters when defining level in Area properties. Example: If level name is 63 in level manager, "63" is required when defining area using levels
