| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
IP Cannot see all my printers in the IPLOT dialog box--We just added a new InterPlot Server to our domain and when I open the IPLOT dialog box, I cannot see any of the printers on this new server. I can manually key-in the UNC path to the device and I can get a plot out.
The affect you are seeing is being caused by the variable:
IP_PRINTER_FILTER_LIST =
in the file IP.CFG. This variable controls the display of printers in the IPLOT dialog interface and InterPlot Organizer printer selection lists. The variable takes a semi-colon separated list of wildcard patterns. Only printers that match a pattern in this list will be shown. Note: this variable only influences the list of printers shown in the selection lists only. You can still type in any valid printer name or use a settings file with that printer.
