| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
How can "Use Full Sheet" be disabled in the IPLOT dialog box?--User is selecting a layout view, and when selecting this view, "Use Full Sheet" is automatically selected. How can the user disable this feature?
KB: Add "-full_sheet=false" to the users settings file to turn off "Use Full Sheet" by default.
