| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
IPLOT Command plots get watermark--Organizer and the IPLOT dialog give good plots but the IPLOT submit command line gives a watermark stating that InterPlot Client is not registered.
The user is probably generating and submitting an old IPARM that was created when the license file was not present or expired. Recreate the iparm and the watermark will go away.
