| Product(s): | InRoads | ||
| Area: | Geometry | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
How can I change the current style of my cogo points to a different style?
Select Geometry>Cogo Points>Edit Multiple. The filter can be used to select the desired Cogo points to modify, and then select Reassign Style, select your desired style, and then Apply.
