| Product(s): | InRoads | ||
| Area: | Tools | ||
| Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Is it possible in InRoads to export the named symbology to a CSV file?
In order to export named symbology to a CSV file, you will need to enable the Named Symbology Tools Add-in by going to Tools>Application Add-ins.
These commands can now be found in Tools>Named Symbology Tools.
The Export Named Symbology to CSV command can be use to export named symbologies to a file(s) you designate. A named symbology stores a large set of parameters that define exactly how a point, line, or piece of text will appear in plan view, in profiles, and in cross sections.
This command is not available when running AutoCAD.
