| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
Text using a text style is plotting as a black box when using a pen table.
The pen table is assigning color (0,0,0) to the text element causing the text with a text style that has a background to plot
as a black box. Add the statement fill_color=(255,255,255) to the pen table to keep the background white causing the mask appearance.
The text must be a Bentley font and not filled for this to work.
