Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Area: | Geometry | ||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
I would like to display dual dimensions, both feet and meters along my alignment. How can this be accomplished?
In setting up the Dual Annotation, the Primary Abbreviation (feet) should be set in the Style Manager>Geometry Features>Suffix. The Alternate Abbreviation (meters) should be set in Project Options> Abbreviation>Dual Dimension>Suffix. After settings are implemented, select View Horizontal Annotation> Dual Dimension, dual dimension with dimensions annotated as feet and meters should be displayed.
