| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
Takes long time to plot geopak files - When plotting design files from Organizer with geopak reference files attached, the length of time it takes to process these jobs is unusually long.
Edit iplot.cfg and add the following variable:
IPLOT_IGNORE_REFS_OUTSIDE_PLOTAREA=true
