| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | 08.11.07.420 | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
Is there is a way to enable the "Disable Saved Views/Reference Bookmark" option via a variable or registry change? This option is located under "PDF Format Configuration" after selecting the Export to PDF option in Organizer.
Create the following registry key:
HKLM\Software\Intergraph\IpServer\CurrentVersion\NoSavedViewsReferencesBookmark
If this key is available then No Saved Views or References Bookmark entries should be created regardless of what is set in the dialog. However the dialogs value for this setting is now meaningless, and it will not reflect what is set in the registry.
