| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
What dictates line weights in an InterPlot Organizer Exported PDF file?
The target printer defines the resolution for how line weights appears. This behavior is consistent with the Digital Archives behavior also. The PDF Configuration dialog for resolution seems to be a cause for confusion.
