| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Todd Combs, Bentley Technical Support Group | ||
What is the Rasterized Option in InterPlot?
All three plotting interfaces (Organizer, command line, and IPLOT Dialog) support a new Rasterized option. This option is useful for plotting a MicroStation V8 XM rendered view or a view that contains transparency. All vectors will be converted to raster data when you set the Rasterized option.
