| Product(s): | BENTLEY INTERPLOT CLIENT | ||
| Version(s): | N/A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Marion Powell, Bentley Technical Support Group | ||
When plotting design files containing true type fonts, the fonts do not seem to be recognizing the correct pen weights assigned to them. How can I get them to plot with the assigned pen weights which are being set by a design script?
You cannot assign weight to a True Type fonts. You'll have to use non-true type fonts.
