The following resources are provided as a reference by Bentley's Technical Support Group. They encompass the Bentley InRoads products.
- Video: Angle Distance Constraint
- Video: Assembling Templates
- Video: Benching End Condition
- Video: Building Components
- Video: Creating A Simple Template
- Video: Creating Slopes At Bridge Abutments
- Video: Curve Widening
- Video: Display Rules
- Video: Driveway Components
- Video: End Condition Exceptions - Overrides
- Video: End Condition Exceptions - Transitions
- Video: End Conditions
- Video: End Conditions P2
- Video: Fill Ditch - Seeking Second Intersection After First Has Solved
- Video: Horizontal And Vertical Max-Min Constraints
- Video: Horizontal Vertical and Slope Constraints
- Video: Intersection Design - Roadway Designer
- Video: Midpoint Constraint
- Video: Overlapping Slopes at Intersections With Relatively Long Cut/Fill Slopes
- Video: Overlay Example
- Video: Parametric Constraints
- Video: Parent Component
- Video: Project to Design Constraint
- Video: Project to Surface Constraint
- Video: Seek Last Intersection of a Surface
- Video: Style Constraint
- Video: Super Rollover on Inside Median
- Video: InRoads 8.9 Superelevation
- Video: Template Transition Example
- Video: Template Transition in Superelevation
- Video: Using Value Equations in a Template Point Constraint
- Video: Vector-Offset Constraint
- Video: Vertical Gore Tool
- Video: View Components
