Common reference files are getting copied out multiple times out of ProjectWise when plotting from O
 Product(s):PROJECTWISE INTERPLOT ORGANIZER
 Version(s):xx.xx.xx.xxx
 Environment: N\A
 Area: IPLOT
 Subarea: N\A
 Original Author:Todd Combs, Bentley Technical Support Group
Common reference files are getting copied out multiple times out of ProjectWise when plotting from Organizer.
Using ProjectWise Explorer > Tools > Options > Settings > Document, enable "Use up to date local copy on copy out".
