| Product(s): | PROJECTWISE INTERPLOT ORGANIZER | ||
| Version(s): | N\A | ||
| Area: | IPLOT | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group | ||
How do you get the Welcome dialog to display when opening Organizer once you have selected the option to "Don't display this screen again"?
Modify the following registry key:
HKCU - Software - Intergraph - InterPlot Professional - ProjectWise InterPlot Organizer - Options - ShowWelcome
Set this key to 1.
