Applies To | |||
Product(s): | InRoads | ||
Version(s): | N/A | ||
Environment: | N/A | ||
Area: | Roadway Designer | ||
Subarea: | |||
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Why are changes to templates that have been edited in the Template Library not being reflected in Roadway Designer?
If you have edited templates in the Template Library (*.itl) and you would like the changes to be reflected in your Roadway Designer file (*.ird), you will need to synchronize your template library with your template drops. From within Roadway Designer, go to Corridor>Template Drops. Highlight the template drops that you would like to synchronize and click on the "Synchronize with Library" button in the bottom left-hand corner.
