Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Area: | General | ||
Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
When selecting a command such as Evaluation>Profiles, the dialog boxes are transparent. This behavior is isolated to one computer.
This behavior can be resolved by selecting Control Panel\All Control Panel Items\Personalization\Window Color and Appearance. Here you can disable transparency.
