| Product(s): | InRoads | ||
| Version(s): | 08.11.09.674 | ||
| Area: | Terrain Model | ||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
I would like to export the Component Properties description, can this be done? Can this description be written to an XML report?
If the user’s components have a description prior to creating and processing the corridor, component descriptions can be written to an XML report. Once the corridor is processed, the user can select the Design Input Report (from the corridor fly-out menu) and then, the TemplateDropsConstraints.xsl can be used to view the component descriptions.
