Applies To | |||
Product(s): | InRoads | ||
Version(s): | 08.11.07.615 | ||
Area: | Roadway Designer | ||
Original Author: | Jacquelyn Pettus, Bentley Technical Support Group | ||
Is there a way to convert RWL and TML files to IRD and ITL files, respectively?
In Roadway Designer, go to Files>Import RWL. Use this dialog box to translate existing binary roadway library (.rwl) and typical section library (.tml) files from previous versions of InRoads to the XML-based InRoads .ird and .itl files, respectively.
